timing question
Old Jul 1, 2007 | 11:14 AM
skielk's Avatar
skielk
Default timing question
I was wondering if anyone could tell me a good place to start, I just put in a new distributor and I was just wondering where I should set the timing. The car is a 1995 Mustang Gt with a Kenne Bell supercharger. I'm just looking for a ball park area to start, I bought the car modified already so I have no way of knowing the tune on the car. Right now I put the distributor it at 13 degrees btdc and it seems to run ok, any advice would be great. Thanks
Old Jul 1, 2007 | 11:59 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: timing question
if your running boost you should have it set at 10* and have it dyno tuned. they will be able to program it to pull timing as boost is being made
Old Jul 1, 2007 | 12:59 PM
skielk's Avatar
skielk
The car has been dyno tuned in the past, 10 degrees is stock isn't it? It was my understanding that timing should be retarded when boost is added. I'd rather run the car with less timing and make less power just to be safe since at the current time I don't have the money to go to a dyno shop and get it tuned again.
Old Jul 1, 2007 | 01:06 PM
luckythirteen13
are you boosting the motor with 13* base timing? 10* is stock. if you can go full boost on 13* base then the car may have a chip in it that is pulling timing because it should be pinging. if you havent boosted yet, set the timing to 10* base and get an msd btm box. it will pull timing for you as you build boost. its the best thing you can do without going to a dyno tuner or buying an ems
Old Jul 1, 2007 | 02:13 PM
skielk's Avatar
skielk
I'd like to be conservative, at this point i'd rather be safe and make less power so should I run it at 8 degrees? I'm not sure what the tune is like that has been done to the car and I have no way of finding out.
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
