Gauge cluster question
Old 07-03-2007, 08:09 PM
tankard
tankard's Avatar
Default Gauge cluster question
The gauges on my gauge cluster specifically the water temp and oil pressure seem to have a mind of their own. My oil pressure is way off the indicator on the high side and my water temp seems to go higher the faster I go. When I slow down or stop it comes back to normal. I also noticed that if I am stopped and I take my foot off the brake the water temp gauge comes back to the middle. This worries/annoys me because my car is leaking a bit of coolant so I don't know if it's overheating or the cluster is just screwed up. Anybody have the same problem? I heard something about a ground wire how do I fix this problem?
An update. Basically every time i press the brake, put the windows up or down, the top up or down or any kind or electrical activity (brake light?) the gauges start moving up . When I stop doing these activities, they go down so i'm guessing it's an electrical problem?
ok so i've been doing some research .... a few hours later I came up with this answer: gauge cluster voltage regulator?? anybody know if I can buy this part from ford or do I have to swap the cluster?
tankard is offline
Old 07-04-2007, 11:00 AM
stang8689
stang8689's Avatar
Default RE: Gauge cluster question
stock guages suck, get autometer
stang8689 is offline
Old 07-04-2007, 02:10 PM
90mustang5.8
I ♥ Acer
90mustang5.8's Avatar
autometer FTW!
90mustang5.8 is offline
Old 07-04-2007, 07:37 PM
tankard
tankard's Avatar
oh yeah great answer both of you .... how come I never thought of that????
tankard is offline
Old 07-04-2007, 07:49 PM
1985stang
1985stang's Avatar
ORIGINAL: tankard
Haha, it is a pretty good idea.
1985stang is offline
Old 07-05-2007, 03:12 PM
McNasty11jm
McNasty11jm's Avatar
yes i have that same problem....i boughta voltage regulator from www.50resto.com and it comes in today....hopefully it works
McNasty11jm is offline
Old 07-05-2007, 03:23 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
it will work. you need aftermarket gauges. the stock one are old and hardly work anymore, its electricle type and they run off interpretation so its either pressure or no pressure. it doesnt actually measure accurately how much psi your running. the temp gauge should be close, but again its older than dirt so its probably going out as well. just get some aftermarket gauges and call it done. you can get some gauges at autozone for 40 bucks volt, temp, and oil pressure gauges, good instructions.
FivePointOhh is offline
Old 07-05-2007, 03:44 PM
McNasty11jm
cool thanks
Old 07-05-2007, 11:40 PM
daleclough
daleclough's Avatar
So I am understanding that Autometer gages (assumed to be mounted on the A-pillar) is the best (ie. most accurate) way to go.
My fuel and oil pressure gauges are possessed.
Oil pressure can be remote (ie. Autometer) but what about fuel gage?
daleclough is offline
Old 07-06-2007, 11:24 AM
piedraco
piedraco's Avatar
florda50.com check that out, just got mines yesterday, they are sick
piedraco is offline
Quick Reply: Gauge cluster question
