heres what happened i picked up a motor from someone i know and they removed the distributor for some odd reason. so i dropped it in this past weekend and today i would adjust the timing and then try and start the car. it would start but not turnovermeaning that i was missing. i did this like 3-4 times and after each time i tried to start it i adjusted the timing again. the last time the car sounded like it backfired and after adjusting the timing again it wouldnt start. there was no smoke on any of the startups and i made sure that everything was connected. i cleaned the terminals everywhere and made sure that the connections were solid and the solenoid cant even be jumped but the battery has juice (12v).
does the solinoid click? any noises at all?pull all the plugs out and try to turn over the engine by hand.start over everything you did, sounds like spark plug wires my not be on correct.
