looking for more power! heres my specs.
looking to add more power without adding a supercharger.any suggestions?
Cast Iron Custom Ground Crank Assembled New Clevite 77 Rod And Main Bearings
A Set Of I-Beam Ford Factory Forged Connecting Rods that are checked for straightness and re-balanced
A Set Of Keith Black SILV-O-LITE Pistons (9.8:1 CR)
High Performance Moly Rings
A Three Piece Cloyes Street Racer Double Roller High Performance Timing Set
New 50oz. Ford Motorsport Nodular Iron Damper
Head Specs:
Trick Flow's Twisted Wedge Aluminum Cylinder Heads (Pt# TFS-51400002)
TFS Silver Powder Coated Valve Covers
ARP Valve Cover Stud Bolts
61cc Combustion Chamber
2.02 Intake Valves
1.60 Exhaust Valves
High Rate Valve Springs, 7 Degree Locks, & Manganese Bronze Guides
Trick Flow 1.6 Ratio Roller Rocker Arms
Assembled with ARP Hex Head Chromemoly Steel 170,000psi High Performance Head Bolts
Cam Specs:
Brand New Trick Flow Track Heat Camshaft (Pt# TFS-51402000)
Lift: .499 in. intake / .510 in. exhaust
Duration: .275 intake / .279 exhaust
Lobe Separation: 112 Degrees
Power Range: 2,000 to 5,500 rpm's
Brand New Ford Motorsport Racing Hydraulic Roller Lifters (Pt# FMS-M-6500-R302)
Brand New Trick Flow Chromemoly Hardened Racing Pushrods
Trick flow track heat upper and lower intakes
75mm professional products throttle body
76mm mass air flow
24lb ford racing injectors
bbk shortie headers
aod trans
3000 edge racing stall converter
shift kit
373 gears
Head Specs:
2.02 Intake Valves
1.60 Exhaust Valves
Cam Specs:
76mm mass air flow
bbk shortie headers
aod trans
shift kit
373 gears
RE: looking for more power! heres my specs.
Very nice setup you got there. Give us some shots of the engine bay!
But to get to your question... without forced induction or nitrous, there's not much you can do that won't take away from previous purchases. For example, ditching the Trick Flow heads for a nice set of AFR heads. That would be a nice increase but it involves you losing the heads you paid for. Same thing with teh camshaft... swapping it out with a custom grind.
Something you can do... you can look into ditching th 1.6 RRs and getting 1.7s. That will help a little. And even that won't be a huge gain. I didn't see any mention of having it tuned. That always helps. You've bolted on pretty much everything you can at this point. Like i said before, if you want a big jump in numbers it's going to be pricey from here on. You could always stroke it out to a 347. Of you could increase the compression and run some higher octane fuel.
Why do you want to avoid a supercharger?
my phone is not worth a crap for pics sorry bout the quality.
the main reason i want to stay away from forced induction is because i swore that
i was going to stay all motor.plus shes my dd.i have dumped alot into this car since
april 2nd when i dropped my front main bearing in the stock 302.dont get me wrong shes got awesome power,but as with anything u jus get use to it and want more.ive sprayed it a couple of times but i dont want to damage it.O and the tune i have done myself. she runs best 0.80v tps 14 degress of timing and 40 psi at the rail on 24lb injectors running 3 gallons of 110 to a full tank of 93
LoL. I know what you mean about "getting used to it." I have the same problem. Last I checked I was pushing 320hp to the wheels without nitrous, 430 with it. And I've made several additions since then. After awhile, it feels slow!
ORIGINAL: samseed101
I'm building my 5.0 up hopefully to be a 10 second car (on nitrous)and i'm hoping that doesn't get old!
