detonation
Old Jul 4, 2007 | 06:56 PM
dillon1340's Avatar
dillon1340
Default detonation
sometimes my engine detonates under throttle. i use 93 octane and the base timing is at 10. what could be causing it and what can i do to get rid of it. the engine probably has 200,000 miles on it now but doesnt burn or leak any oil and runs strong.
Old Jul 4, 2007 | 07:08 PM
mattdel's Avatar
mattdel
Default RE: detonation
you have carbon buildup in the cylinders causing an increase in compression ratio.
run a whole bottom of seafoam through the brake booster vacuum while its running. after you've finished, shut it off for 15 minutes, then restart and rev up a little.
Old Jul 5, 2007 | 01:07 AM
dillon1340's Avatar
dillon1340
i've heard about that stuff. i'll try it.
Old Jul 5, 2007 | 05:14 AM
AdderMk2's Avatar
AdderMk2
Banned
water does the same thing....
if you havent done so already.... get a new timing chain
Old Jul 5, 2007 | 11:41 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Could also be a faulty egr system and or worn or incorrect spark plugs.
Old Jul 5, 2007 | 11:47 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
DON'T TRY WATER !! if you don't know what your doing... improperly done it can hydroloc a motor use a substance that many parts stores sell that is burned through the cumbustion process. BG PRODUCTS MAKES a induction clean set up that is industrial strength that comes with the heavy duty induction cleaner and 44k for the intake fuel system works great!!
Old Jul 5, 2007 | 12:23 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: mjr46
seafoam can hydrolock the engine too newb
Old Jul 5, 2007 | 12:40 PM
dillon1340's Avatar
dillon1340
i forgot to mention it doesnt do it all the time. i think it's mostly when it's hot outside.
Old Jul 5, 2007 | 12:44 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: dillon1340
check your ACT sensor
Old Jul 5, 2007 | 12:49 PM
dillon1340's Avatar
dillon1340
act is only a year old, if that. it went bad last year, threw a code so i replaced it. but i guess it could be bad again. dont know how to check them so maybe i'll run up to napa today and get one.
