VICTORY!!! (updated, engine out...pg 3)
Old Jul 7, 2007 | 10:01 PM
  #51
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default RE: VICTORY!!! (updated, engine out!)
pics or it didnt happen
Old Jul 7, 2007 | 10:21 PM
  #52
my77stang's Avatar
my77stang
bolt pattern means nothing. you could have two flywheels both from 302's that looked identical and would both bolt to the same crank. once is a 28oz, and one is a 50oz.
you NEED to find out before you install, don't take anyones "yeah it'll work" advice - find the facts...... whats the imbalance on a 3.8? find that and you'll know
Old Jul 8, 2007 | 12:14 AM
  #53
Shelty's Avatar
Shelty
ORIGINAL: my77stang
Ive been searching the net, havnt found much, but is there any markings on a flywheel that would give away its size? like a stamping or something.
Old Jul 8, 2007 | 12:16 AM
  #54
my77stang's Avatar
my77stang
according to autozone,
'86 3.8 flexplate is a Pioneer part # FRA-225
'86 5.0 flexplate is a Pioneer part # FRA-214
looks like you struck out [>:]
Old Jul 8, 2007 | 12:18 AM
  #55
Shelty's Avatar
Shelty
ok, I'll have to check that before I go to work in the morning...
anyone know the part number on the 28 oz flywheel?
Old Jul 8, 2007 | 12:20 AM
  #56
my77stang's Avatar
my77stang
check out my above post, edited..... and about to edit it again
Old Jul 8, 2007 | 12:22 AM
  #57
Shelty's Avatar
Shelty
http://www.bsbraceparts.com/PartDetail.cfm?ID=39959
I dont know if this answered the question of the flywheel
Old Jul 8, 2007 | 12:24 AM
  #58
my77stang's Avatar
my77stang
depending on if your motor is a one piece or two piece rear main seal..... but im confused at the different O.D.'s cause wtf they should both be mating to a C4 bellhousing and therefore the spacing to the starter teeth should be the same.
im friggen lost now
Old Jul 8, 2007 | 12:26 AM
  #59
Shelty's Avatar
Shelty
ORIGINAL: my77stang
that is a 5.0 flywheel?
Old Jul 8, 2007 | 12:29 AM
  #60
my77stang's Avatar
my77stang
the first one was from a 73 mustang 302, the second one was from a 86 mustang 5.0..... see the difference in the balance? but the OD is still confusing the hell outta me
