MSD Iginition
Old Jul 7, 2007 | 03:03 PM
hawwk11's Avatar
hawwk11
Default MSD Iginition
How to install properly and whats the good and bad about MSD Igini Box I have a 91yr, 5.0 GT
Old Jul 7, 2007 | 03:10 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: MSD Iginition
follow instructions they come with. or download them from msd's webpage. the instruction packet has a complete listing of how to's depending on what distributor you are using whether itbe stock or a msd one. and keep the box away from engine bay heat the best you can.
Old Jul 7, 2007 | 03:11 PM
stang8689's Avatar
stang8689
get the tfi harness, it plugs into your coil and allows easy install, check any mustang supplier
Old Jul 7, 2007 | 03:15 PM
hawwk11's Avatar
hawwk11
what is the advantage of MSD Box and Negative and I want to use my stock Distributer
Old Jul 7, 2007 | 03:17 PM
hawwk11's Avatar
hawwk11
can I get the full name of the MSD Web pages and thanks guys you are saving me alot of money I am doing it myself
Old Jul 7, 2007 | 03:19 PM
mjr46's Avatar
mjr46
on advantage is it produces a hotter spark than stock ignition and less likely to break down during higher rpm's disadvantage ?? I've never had any problem with mine other than I've had to replace the box once or twice because it burned out but then again I run the crap out of the car and race it AT THE TRACK
Old Jul 7, 2007 | 03:20 PM
mjr46's Avatar
mjr46
www.msdignition.com if you get a msd box get a 6al for non boosted applications and it comes with the rev limiter chips well used expecially if you miss a shift.
Old Jul 7, 2007 | 03:26 PM
angcobra's Avatar
angcobra
It will perform better and last longer if you mount it in the passenger compartment rather than under the hood.
Old Jul 7, 2007 | 03:27 PM
SoDakStang's Avatar
SoDakStang
ORIGINAL: mjr46
He is right. I just put a 6a digital on my car and the box fried one month after install. It was correctly installed. It's VERY easy to install. Anyone can do it if they know what colors are. Basically, if you have higher compression/resistance in the combustion chamber, msd is worth it. If you have a stock car, it really won't do ****.
Old Jul 7, 2007 | 03:30 PM
hawwk11's Avatar
hawwk11
Default RE: MSD Ignition
I have a supercharger Vortex with 6psi but using ignition stock someone recommend a MSD Box so I will try it and thanks
