MSD Iginition
Old Jul 7, 2007 | 03:33 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: MSD Ignition
since its supercharged I'd buy the msd btm it has built in retard an added feature for when you up your boost you can manually retard the ignition to reduce possibilty of detonation
Old Jul 7, 2007 | 04:37 PM
CantStopTheFox...'s Avatar
CantStopTheFox...
Default RE: MSD Iginition
ORIGINAL: stang8689
get the tfi harness, it plugs into your coil and allows easy install, check any mustang supplier
The harness makes installation so much easier.....(and if needed) removal is easier too!
I got mine for under $20
Old Jul 7, 2007 | 04:42 PM
my77stang's Avatar
my77stang
i'll be the left thumb of this thread and tell you to buy a crane fireball ignition system. why? because it has all the features of a msd 6al, plus you dont have to swap chips (buy chips) to change your rev limit, and the rev limiter lets the motor go "whaaaaaaaaaaaaaaaa" instead of the msd limited which is more like "pop-pop-pop-pop-pop-pop-pop" (pop-pop-pop is no-damn-good for your motor)
Old Jul 7, 2007 | 05:34 PM
hawwk11's Avatar
hawwk11
ok where and how do i get intouch with a fireball ignition system I don't want the poping noise
Old Jul 7, 2007 | 07:11 PM
angcobra's Avatar
angcobra
Since you have boost, spend the money to get an ignition box that has boost retard built in. This allows you to run a higher initial timing and have it retard as the boost builds.
Old Jul 7, 2007 | 07:19 PM
WhiteWindsor's Avatar
WhiteWindsor
The digital 6 plus has worked great for my car. I have it bolted to clear plexi-glass in the engine bay, i have never had a problem with heat damaging it. The box has a two stage rev limiter and retard switch for starting car and for nitrious, you just use a small flat-head and adjust to whatever rpm's and how many degrees you want to retard. The stock dist. is probably a good idea, i just sheared 5 teeth off of my MSD dist. I hope the dist. was bad and not my cam gear or retainer plate. I have not checked yet.
http://s194.photobucket.com/albums/z112/keithswearingen/?action=view¤t=c3a71cc9.pbw
Old Jul 7, 2007 | 07:56 PM
my77stang's Avatar
my77stang
http://www.cranecams.com/?show=brows...mber=6000-6301
boost control included if you use a map sensor (cheap and easy to get and install)
firehorse02
Nov 16, 2015 11:28 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
cjoracing
Jan 6, 2004 03:17 AM
af41
Nov 15, 2003 08:42 PM
