High Speed Vibration
Old Jul 8, 2007 | 02:48 AM
hectanooga's Avatar
hectanooga
Default High Speed Vibration
While I was on the freeway today I noticed a vibration in my car that I'm pretty sure wasn't there a month ago. It really only does it when the car is cruising or coasting. If there is power going through the transmission its smooth as can be. As soon as you let off the gas though, there it is. I don't know if my rear is going out or what. I'm not quite sure what it is so, any help would be appreciated. Bytheway, I have a T-5 tranny if thats makes a difference.
Old Jul 8, 2007 | 02:53 AM
samseed101's Avatar
samseed101
Default RE: High Speed Vibration
Does it vibrate at certain speeds or certain RPMs? If it's speed related and not RPM related.. have you checked your tires lately? Could be something in them, could be off balance, tire could be damaged / cupped, etc.
Old Jul 8, 2007 | 02:57 AM
hectanooga's Avatar
hectanooga
I notice it more at higher speeds, but its pretty constant. The tires are fine, in fact I checked them already. RPM's don't seem to matter either...
Old Jul 8, 2007 | 11:43 AM
nitrous_bob's Avatar
nitrous_bob
99% sure it is wheel balance
the rest if it's stock is usually fine
Old Jul 8, 2007 | 01:59 PM
hectanooga's Avatar
hectanooga
ORIGINAL: nitrous_bob
I don't see how it could be wheel balance if its not doing it all the time though. Under acceleration it goes away. Is this normal if a wheel is out of balance?
Old Jul 8, 2007 | 02:57 PM
blkonblk5.0's Avatar
blkonblk5.0
ORIGINAL: hectanooga
you probley just dont notice it when your accelerating....where is the vibration coming from? steering wheel, rear, front, the whole car? shifter?or what.
Old Jul 8, 2007 | 03:25 PM
hectanooga's Avatar
hectanooga
You can pretty much feel it coming from the entire car, but it seems localized in the rear.
Old Jul 8, 2007 | 05:29 PM
hectanooga's Avatar
hectanooga
Well, I discovered the problem and you guys were right. One of my weights came off my left-rear wheel. The clip is still there, but the weight came off. I just overlooked it yesterday since the clip was on. der der.
Thanks for the help guys. I appreciate it!
mtgldr
Feb 3, 2024 09:00 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
mungodrums
Sep 28, 2015 10:54 PM
