catalytic converter...cheap fix?
RE: catalytic converter...cheap fix?
ORIGINAL: samseed101
Cats are very cheap to repair. All you need is a good solid broom handle or long metal bar.
I used a short piece of rebar but one of the cats is at an angle you cant get to it with our cutting the pipe. what I did was cut it off at the weld, knocked the catiylist out, then ground down the old weld a little, mig welded it back together, then put a little salt water to cool it, put a little oil on it and ran it so it "aged' to look like the original weld. That way when they pass the mirror under the car it still looks like the original weld.
ORIGINAL: bmennen07
Can I just gut the converter and not have any problems? Daddy says I cant cause I need back pressure or my valves will be fried. is this true or not?
i dont mean this in a mean way but your dad doesnt know what he is talkin about cause for about 70 years cars were run without cats on them with absolutely no problems at all the only way you will fry the valves like he says is if you run the car with no manifold or header on it
lol k. my dad is use to growing up with older cars like 67 chevelle and stuff hes not really up to current times.
anyways, i didnt really get the broom thing. I was thinking about just cutting the converter off and then going to the exhaust pros shop and buying the pipe to replace the converter. cops in my state dont care at all about it.
So I basically i just cut off the converter, and stick the pipe in its place, and weld it together?
sorry im a newb but im learning. thanks for the help.
ORIGINAL: mattdel
the stock converters dont have heat shields built onto them. the shielding is part of the undercarriage, built into the car.
anyway, you wont bend valves. there wont be a lack of back pressure unless you take the whole exhaust off and run open headers. then you will start messin stuff up.
ORIGINAL: bmennen07
so i took it down to a guy my parents know pretty well. He is making a custom H pipe to replace it, im just supposed to keep it on theDL .
well he made a custom h pipe for me for the back 2. It sound mean now!! Turns out I still hear the same god awful noise. The front 2 are bad as well. Didnt know my car had 4 CONVERTERS!! ughh.
He is putting h pipe in the front 2 tomorrow as well, for free
No converters at all!! idk what hi flows are but he moved the air flow something or nother and it runs great right now, cant wait till tomorrow!!
my town has no emissions stuff or anything like that and plus my uncle is the head of the police department and I know every cop by first and last name so if they pull me over they usually just punch me really hard and tell my parents if something happens.
