speedometer problem!!!!!
Old Jul 10, 2007 | 12:42 PM
NATEDOVER5.0L's Avatar
NATEDOVER5.0L
Default speedometer problem!!!!!
my speedometer works fine up till 20mph them it starts dancing back and forth, then when i speed up it goes to 120mph or so any ideas if its the cable or the gear, any help would be great just need some answers......
Old Jul 10, 2007 | 12:45 PM
blkonblk5.0's Avatar
blkonblk5.0
Default RE: speedometer problem!!!!!
this is a common problem...my mustang does it too....ive changed the cluster, and cable and it still bounces..im changed the VSS next..yea thats probley the cable or the gear there cheap replace it.
frankbullitt's Avatar
frankbullitt
sounds like its the gear. its a cheap and easy part to fix.
Old Jul 10, 2007 | 01:13 PM
NATEDOVER5.0L
thanks i will try the gear and see if it fixes it...
Old Jul 10, 2007 | 01:18 PM
Tony71502's Avatar
Tony71502
In my case the cable was kinked and speedo head was broken.
Old Jul 10, 2007 | 02:12 PM
NATEDOVER5.0L
well tahts what i was also thinking but every once i a while under 30mph around 20mph it works fine the faster i go the more it bounces
Old Jul 10, 2007 | 02:58 PM
nacanitihs's Avatar
nacanitihs
could be the speed sensor mine was broken causing the needle to hop around everywhere
articman
Jun 21, 2018 11:45 PM
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
