5 lug questions...
5 lug questions...
OK so I'm workin towards doin a 5 lug swap eventually and I'm tryin to figure out a parts list and what not. I was lookin on jegs and I was just gonna buy some new 5 lug rotors for the front, and for the rear I was just gonna get some 5 lug moser 31 splines or osmethin. Now for the rear if I'm gonna keep drum, then can I just get the drums off of an f150 or something similar to run with the 5 lug axles? on jegs they want 400$ for a set of 5 lug axles and drums. When from as far as I've seen a new set of 5 lug 31 spline mosers is like 150$. so if I can get the drums from a junkyard then that would be good. Am I missing anything? Thanks.
RE: 5 lug questions...
You can get 5 lug rear set-ups from FRRP's for about 299 with axles and everything you need for the conversion. Late Model Resto would be a good place to start. If you want 31 spline axles then yes you will spend good money on them. If what you want is good quality OEM 5 lug conversion go with the FRRP set-up.
inyadreems
08-21-2015 09:10 AM
Fast-Hands
08-19-2015 06:54 AM
