Best Combo duplicate thread
Old 04-18-2014, 06:55 PM
Ineedmorespeed
Ineedmorespeed's Avatar
Default Best Combo duplicate thread
This is my plan, I have a pretty much stock 95 5.0 5 Speed. I want do do a few lesser expensive upgrades. I've already put gears in it. I want to do a few motor Upgrades, Smog delete and Underdrive pulleys. I have a 70mm Throttle body and an 80mm Mass Air sensor arlready calibrated to 19lbs injectors. I have also came across a set of gt40 and gt40p heads they are both home ported and polished and gasket matched they look really good, Not sure on the flow numbers though. Also Have GT40 upper and lower intake both also home ported and polished and gasket matched. I want to know what else I can/should do too, would like to upgrade the Cam as well. Thinking e303 or something close..
What would be the best combo...
Heads Gt40 Gt40p
Intake Gt40 ????
Cam e303? ?????
Throttle Body 70mm
Mass Air 80mm
I Just wanna know if and what will work best together, Im not looking for some crazy power just wanna know what with this stuff would work best. Its my Daily Driver and just looking for a little more pep. With this stuff what else Should I be looking for and/or replacing? and Whats the best combo? I have everything except the Cam and anything else not listed...
Ineedmorespeed is offline
Old 04-18-2014, 07:03 PM
bluebeastsrt
bluebeastsrt's Avatar
honestly I'd look for some better heads, intake etc. you should be able to find the parts used. I'd go with trick flow, edelbrock, etc.
bluebeastsrt is offline
Old 04-18-2014, 07:41 PM
Ineedmorespeed
I dont have tons of money to put towards it all. I already have the gt40 and gt40p heads and the gt40 intake, Mass air and throttle. I wanna use these parts as I already have them, Just really wanna know the best cam to match with what combo I have. And if I Need to replace anything else with this..
Old 04-18-2014, 08:48 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
pleaSE do not create multiple threads on the same subjuect...you already have one in gen disc, use it, thank you, thread closed
mjr46 is offline
jwog666
12-27-2021 08:09 PM
Dokilar
15
10-16-2015 08:13 PM
KingRando
10-02-2015 08:06 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: Best Combo duplicate thread
