how much vac?
how much vac?
So how much vacuum shouldI be pulling at idle to run normal. carbed 306 with the stuff in my sig. the previous owner had vacuum problems before but with a stock single plane intake and a holley carb. I have the performer intake and carb. ill be testing tomorrow to see what i am pulling at idle and while revving. i dont seem to have enough for my brakes (stock 83 v6 setup).
RE: how much vac?
so what is it in a cam's specs that give it low or high vacuum? and on my brake booster whaich place would be better to hook it up? I eliminated the plastic tree on the firewall and just have a tree in my intake. but would that be better or the port in on the back of the carb designed for power brakes. both should be pulling the same vacuum since it is under the butterfly's on the carb correct???
RE: how much vac?
so your running a big vac hose from the booster all the way to the intake?
partial reason for the secondary tree is to create a bit more vacuum in the lines, by using a small hose up to the tree.
RE: how much vac?
ORIGINAL: mattdel
RE: how much vac?
I'm running the same size hose from the manifold to my booster, its just a little longer. the motor is the only thing the previous owner had. my brother and i eliminated the plastic tree to help clean up the firewall a little. didnt think it would affect the vacuum much. and it thats the case should i just run one smaller hose from the manifold to the plastic tree and the split the lines to where they need to go????
RE: how much vac?
when you do go do the measuring mattdel draw up a diagram of where the lines on you tree go. all i really need is the intake into the tree, the brake booster, and the hvac line.
Thanks
Thanks
