different year t5
Old 07-26-2007, 10:50 AM
chrizzle17
chrizzle17's Avatar
Default different year t5
will a t-5 from a 1995 5.0 fit into a 1987 5.0, or do you need a different bell housing and so on? I can get one cheap but am not sure if it will fit.
Thanks
chrizzle17 is offline
Old 07-26-2007, 11:17 AM
wolverine8490
wolverine8490's Avatar
Default RE: different year t5
Im actually wondering the opposite . Will a 91 T5 fit into a 94-95... But from what I have read, the 94-95 will not bolt directly into a fox without a spacer of some type. But I dont know why yet.
wolverine8490 is offline
Old 07-26-2007, 12:47 PM
RanDJ8487
RanDJ8487's Avatar
Why don't you guys trade? lol
RanDJ8487 is offline
Old 07-26-2007, 12:52 PM
dimebag
dimebag's Avatar
ok ignore w/e info is above in this thread...
heres the deal
the transmisson itself is the same... however... on the 94/95s the input shaft was slightly longer, along w. the bell housing... what that means is for the fox guy wanting to use the sn95 trans.... you need to get a foxbody input shaft and bell housisng... easy job... to me yes... to you, well thats for u to decide...
and for the other dude, its just the opposite... fox t5 will be too short... need to use an sn95 input shaft
dimebag is offline
Old 07-26-2007, 04:00 PM
wolverine8490
Yeah, it looks like the 95's input shaft is .67 inches longer than the fox input shaft. I am going to try and put it in anyhow, and see what happens. I would think all that it will effect is the crossmember, the driveshaft, and maybe the whole where the shifter drops in on the inside.
Old 07-26-2007, 06:03 PM
nyfreakinrican7
nyfreakinrican7's Avatar
Why would you go through the trouble of putting a tranny in to see if it would work when you have been told it will not you need to change the input shaft to the longer 94-95 shaft and use the bell housing from your vehicle or use the 91 t-5 and bell housing and then deal with how the shifter will fit now further up in the tunnel.
nyfreakinrican7 is offline
Old 07-26-2007, 06:16 PM
dimebag
dimebag's Avatar
hah have fun... it wont work... not right anyway
dimebag is offline
Old 07-26-2007, 06:40 PM
wolverine8490
Yeah, well, I had to see it for myself, and let me say, you all know your stuff. Not even close. It is amazing what .67 inches does. Well, that just sucks. Guess Ill be buying an input shaft and bellhousing now. I do appriciate all the help, and I was not doubting anyone.. It was just one of those thing that I had to see for myself and see if I could make it work, but there is no possible way.
Old 07-26-2007, 07:25 PM
wolverine8490
Ok, so I am going to swap the input shaft, and the bellhousing. Will the bellhousing from the 3.8L V6 work with the 302?
Old 07-26-2007, 07:27 PM
mattdel
mattdel's Avatar
ORIGINAL: wolverine8490
come on...
really?
really?
mattdel is offline
Quick Reply: different year t5
