timing q's
timing q's
i wanted to try to advance my timing but i havent tried yet but when i point the gun at the numbers on the balancer how to i set it,do i set it by when the nuber and the light flash and meet at the same time. i am very confused. i know i need to connect the gun up, mark on the balancer where i want it to be set at and loosen the dristributer and move it but how do i tell when it is matched up does the gun project the number. how do i tell what it is set at now
RE: timing q's
connect the timing gun to the battery and the clip to number one plug. stock timing is 10 degrees so mark on the balancer 11 12 13 so on with white out. so say if you want to set your timing to 13 you mark 13 on the balancer with white out and set the gun from 0 to 3 so in other words 10+3= 13 degrees obviously. then just unbolt the distributor a little bit just to be able to move it. dont take out the bolt! then start the car point the gun at the balancer and move the distrib until the whiteout line matches up and becomes flush with the indicator. then tighten the bolt.
RE: timing q's
You dont have to adjust the gun. 92 is correct. Clean your balancer so you can see the numbers and follow the above directions. Dont forget to remove the spout connector that is inline with the ignition module mounted to the distributor before you adjust your timing. When you have it set at what you want, put it back. It just pulls out. The gun will pulse light by the spark on the number 1 cylinder. Connect the clamp around the plug wire that goes to the front cylinder on the right(passenger side). The alligator clamps to the positive terminal on the battery. If you hear the engine pinging when you are turning the dizzy, back it off. You should be safe for a 3 to 4 degree advance.
RE: timing q's
This should be of some help.
https://mustangforums.com/m_3621954/tm.htm
https://mustangforums.com/m_1531258/...tm.htm#1531258
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
