Getting new wheels and tires, need help
Alright I have the stock pony rims, I found out they are 16x7. I wanted to go with draglites or something similar to them. Maybe 16x6 in the front and 16x7 or 8 in the rear. Will the 16x8 fit without rubbing or should I go with the stock size, just a wider tire?
I dont want to have any rubbing problems but I want the rears to be a bit wider than the front, but no skinnies, heh, thanks for any info!
RE: Getting new wheels and tires, need help
Also some other questions.....
Why is it so hard to find rims with a 4 bolt circle or am I just reading the numbers wrong?
Should I use 15 inch rims instead of 16 inch? It seems that most draglites are in 15 inch.
ORIGINAL: 85mustangGT
i have 15x8 draglites in the back of mine, and 15x3.5 in the front daily driven with no problems just cant take turns really fast.
Awesome, I really appriciate the info, do thye stick out of the sides at all?
im looking at pro-stars this weekend 15x8 gonna run a 275. 15x2.5 in front. you can run a 10" wide tire on 8" wide rim but i personally wouldnt go much wider.
