temp help!!
Old Aug 2, 2007 | 02:47 PM
frststang's Avatar
frststang
Default temp help!!
so i picked up a 93 gt and they were runing it without a thermastat so i put a 180 in it but just now it climbed past half this is my first 5.0 is this still bad what should i do the water pump looks in good shape i need help oh and when i turned the lights on it went up some more dont know why that happend all the car has is headers full exhaust without cats and an air filter!!
Old Aug 2, 2007 | 02:50 PM
mattdel's Avatar
mattdel
Default RE: temp help!!
does the temp go down if you hold a steady RPM above idle?
Old Aug 2, 2007 | 05:18 PM
frststang's Avatar
frststang
i haventdone that
Old Aug 2, 2007 | 05:20 PM
mattdel's Avatar
mattdel
next time you have the chance, just sit parked and hold it at like 1800rpm. if the temp goes down, you got air in the system.
Old Aug 2, 2007 | 05:37 PM
frststang's Avatar
frststang
if thats the problem how do i get the air out?
Old Aug 2, 2007 | 05:40 PM
mattdel's Avatar
mattdel
burp the system.
take the rad cap off and start the car.
let it idle up to operating temp(could take up to a half hour for this to happen)
when the thermostat opens, the coolant level should drop down.
fill it up and stick the cap on.
done.
Old Aug 2, 2007 | 05:46 PM
AndySpeed's Avatar
AndySpeed
hows you antifreeze look? is it clean? and ya id say air is in you system.. fill up the radiator and hold the gas about 1-1200rpm u should see a air bubble or 2 come up to the top.. at the shop we have a machine for air bubbles in coolany systems and actually hold the thottle to about 2500 to get it up to temp quick and it dose a nice job..
Old Aug 2, 2007 | 05:50 PM
mattdel's Avatar
mattdel
the problem with that is when you let off the throttle, the coolant can burst out of the rad, as if you had just taken the cap off an overheating car.
Old Aug 2, 2007 | 05:55 PM
AndySpeed's Avatar
AndySpeed
deffently.. just sucks whe nya gotta sit for 30mins watchn ur gas go bye bye lol.. but ya the machines are deffently the way to go.. but some times getting it up to temp while in park can be a real pain
67LimeCoupe
Nov 25, 2015 08:55 PM
Spiral534
Oct 6, 2015 04:31 PM
AMAlexLazarus
AmericanMuscle.com
Sep 23, 2015 01:14 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
