Heads and gas mileage?
Old 01-27-2005, 04:44 PM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
Default Heads and gas mileage?
would aftermarket heads and intake help gas mileage? i dont see why it shouldnt because its letting the engine run more efficiently, less strain to pull air in.
remark: remember im talking about cruising conditions, not WOT and stuff, i know that consumes more air and fuel.
Dbeck002 is offline
Old 01-27-2005, 05:14 PM
91hatchgt
91hatchgt's Avatar
Default RE: Heads and gas mileage?
I wouldn't think so, because although it is breathing easier, it still takes in just as much fuel.. It just makes it burn more efficiently, maybe i'm wrong... Just a thought.
91hatchgt is offline
Old 01-27-2005, 09:20 PM
luckythirteen13
luckythirteen13's Avatar
my milage is the same now as it was before i did my heads
luckythirteen13 is offline
Old 01-27-2005, 10:01 PM
Monch
Monch's Avatar
you are right, it does benefit, however the strain that you are relieving is relatively minor (compared to the crappy thermal efficiency of the motor to begin with) and so your gains in fuel economy would be minor.
Monch is offline
Old 01-28-2005, 12:00 AM
EGSRacer
EGSRacer's Avatar
On one of 427SC kits I used a base 92 5.0 plant to start with. When I replaced the stock heads with FRP aluminum ones and went from stock to GT-40 intake upper and lower (all ported and polished btw) I saw a +2 mpg difference. Hope this helps.
EGSRacer is offline
Old 01-28-2005, 01:01 AM
Monch
Monch's Avatar
thats a pretty good gain, but i'd be worried about running a bit lean if i picked up gains like that, if you were not then more power to you.
Monch is offline
Old 01-28-2005, 02:44 PM
roundman
roundman's Avatar
ORIGINAL: Dbeck002
they can but it all depends on how you drive it. it's not so much the strain in pulling the air in but how much more efficient you can make the engine work as an air pump which is what it really is. with the headers you already have you have helped on the exhaust side so reducing flow restrictions on the intake side should yield some gas mileage improvements also if you don't change the way you currently drive now as the engine should be able to make the power needed at a slightly lower rpm if it can breathe better.
roundman is offline
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
69Volunteer
09-30-2015 10:39 AM
mustangheaven
09-29-2015 11:00 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Heads and gas mileage?
