M112 on a 95 GT
M112 on a 95 GT
well i cant find anything anywhere im wondering can is it possible to mount a m112 as my upper intake i have a friend that has a machine shop and is excellent at fabrication would it be possible?
RE: M112 on a 95 GT
there is a guy on another forum that make a bracket setup for an M80 and mounted it on the side of the motor. he did an excellent custom job, and it ended up gaining him about 50whp.
it will not, however, EVER work as an upper intake manifold on a ford. it's a primarily GM based charger, and unless you have access to a plant that manufactures intake manifolds, you aren't going to be able to do it like that.
RE: M112 on a 95 GT
your getting into custom aluminum casting work.
not cheap.
not worth it at all. you would end up spending more to get it all working right, then if you had found a used charger made for these cars.
not cheap.
NYstang
03-05-2008 10:14 AM
