rear sway bar??
rear sway bar??
i just put on my new extreme duty upper and lower control arms from upr. they are fully adjustable but i noticed that there is no were to install the stock sway bar. there are no mounts or anything. should i leave it off or is there something else i can put on there. this is a street only car that i will occasionally drive. no drag racing at all.
RE: rear sway bar??
well these ones are in now and im not taking them out. is there something else i can buy like an anti roll bar or something. or is that for drag racing only? and why cant i run the car with the sway bar out?
RE: rear sway bar??
you can get shock mount brace, but that wont be as good as the sway bar. I didnt have my sway bar in for about a week in my stang after i pu tmy U/L Control arms in and arond Uturns the rear tires would squeel. I put the sway bar back on and problem solved.
RE: rear sway bar??
i didnt order the wrong ones i bought these new off of someone that lived close by and cause he was ended up going with a different combo. but what can i do to solve this problem. should i buy upr's anti-roll bar or? and it says that the links have to be disconnected while on the street so does that mean that i have to disconnect the roll bar to drive on the street cause that would defeat the whole deal.
