351w in a fox
351w in a fox
what you guys think of a 351w in an 88 stang gt. bored .30 over, trickflow "R" series intake, canfield heads(205 cc intake runners) 24# injectors, mallory adj. fuel regulator, MSD pro billet distributor, MSD blaster coil, ford motorsports 9mm wires, A/C n pwr steering deleted, 3:73 gears, tremec T5 trans, subframe connectors, weld draglites, 275/60 drag radials out back, n mickey thompson radials up front, 190 lph in-tank fuel pump, steeda tri-ax short throw shifter. how you guys think she'll be?
RE: 351w in a fox
ORIGINAL: whlte88stang
that setup should give you 450 HP and 11's.
RE: 351w in a fox
Some other things you will have to look at is if the motor is makeing that much power...IE 400+, If you plan to add any power adder you will have to change your fuel system...IE injectors,mass air to match, and fuel pump
