bushings?
RE: bushings?
jack it up from under the control arms and shake down the tire. feel for anything loose.
then take a suitable prybar and put a bit of pressure on the bushings for the control arms.
if there is excessive play in anything, you will feel it.
RE: bushings?
rubber bushing aren't known for squeaking. but if you look and do what mattel said you can find it. i had a squeak once that drove me nuts, searched and searched. finally turned out to be a wheel bearing. sometimes you can use a bit of wd40 to squirt places and when it quiets it down you found your squeak.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-16-2015 07:53 PM
