bypass smog pump.
bypass smog pump.
Im going to bypass the smog pump by getting a smaller belt. What size belt should I use around what size or how do I measure, I have A/c and power steering and pulleys? Is it bad the just bypass the pump, like will the pump freeze up. also how many ponys could I expect also. Im also going to bypass the egr lines also.
RE: bypass smog pump.
just take your belt off and then cut it to the size that you need so that it goes around all the pullies besides the smog and then take the belt to the nearest auto parts store have them measure it and get one that size.
I plan on doing the same to my 94 i was also curious how much horsepower i would get somone said that if you do this that you shouldnt have your cats in your exhaust still what do you guys think?
ORIGINAL: sup95cobra
The biggest gain you get is the loss of weight
