Ignition Options...
Anyone has a Start button for the ignition in their fox? I know there are kits available for the 05-07 mustangs and I was wondering if it would be possible to put one in my 91 Fox.
I found this on 50Resto.com. But it says it will only fit 05-07 Mustangs. Why? What's so different about it that it wouldn't work in an 87-93 fox?
http://www.latemodelrestoration.com/...1&comp=LRS
all it is is a 2 prong switch. input voltage, and output to the starter solenoid.
you can wire it right in, if you know what wires you need to use.
the only reason its states only for 05-07 is because of the hole where it goes.
ORIGINAL: mattdel
bradleyb
Nov 27, 2015 07:50 PM
jessicarabbit
Sep 25, 2015 12:41 PM
