torque box repair
torque box repair
i need to do some welding on my boxes for my new arms that i plan to buy within the next month or so
i need to buy a welder too...
can anyone recommend a good home welder, that will be capable of doing this job?
i'm not looking to spend a grand on some big piece of machinery, i also dont want a crappy one like i've had before.
just a nice little 110v mig that can do the job.
also, should i grind off the existing welds and redo them, or can i just go over the old ones?
i'm not much of a metal man, but i can mig up a bead or two when i have to...
RE: torque box repair
I have a Campbell Hausfeld 105 mig and it works really good for a little welder. I got it because it is a flux core welder but i can also run a solid core wire with argon sheilding gas(makes better welds) I paid around $350 for it a few years back and I don't regret it.
As far as your old welds, I would just clean them up with a grinder and then weld over them.
i lovethe miller arc. ac/dc operation, 10-250amps weld anything with that baby.
edit
migging over another bead wont penetrate and it will be like putting tape over tape. you need to either grind them really good, or get an arc and run a 6011 rod at high amp.
edit
ORIGINAL: jakeachy
edit
edit
ORIGINAL: iceman89gt
. some people just shouldnt give advice when they dont know because i promise you will blow some serious holes with 6010. its stricktly a rod used for penetration. which means it eats like crazy.
ORIGINAL: jakeachy
he needs to get under his old mig bead to make any difference. using a 6011 he can get through his prior bead and a good depth into the base metal. no holes to be blown.
so just how many torque boxes have you done so far? ive done over 15 of them including my own and the only one i used 6010 on was with flat bar as a slug to join the frame and box. even going over the old weld hes gonna be to hot with a 6010. so tell me whats your definition of turning it up hot with a 6010. how many amps on the heat.
ORIGINAL: jakeachy
