Summit Question
Summit Question
ok i've been looking on Summit and right now i got the shortie headers but im looking into the trottle body for my SN95 GT..
summit has this http://store.summitracing.com/partde...p;autoview=sku
will this fit on my engine with no problem.. and would i need bigger injectors for this...?
Thanks r0k0
Thanks r0k0
RE: Summit Question
yeah i know.. the gears count.. but i dunno which to buy and dont have the money for that now.. lol..
but the 65mm trottle body and 65mm mass air flow.. and i think its the 24lbs injector would i see some performance gain there ..? + headers and h pipes.. right now onlt the BBK h pipes i can get..
but i can get some summit shortie headers..
RE: Summit Question
Your stock maf is 70 so dont bother with that, dont bother with injectors unless you got heads and cam or boost and when you do then you can get a dif maf and injectors. Id just save up for gears and heads, those will be the best bang for the buck.
RE: Summit Question
Your mod plans are about as organized as a monkey $hit fight at the zoo. You're all over the place! First off, injectors will do absolutely nothing for you in any way, shape, or form. All they will do is waste your money. If you DO get injectors, you're either going to need to get a tune (again, big waste of money) or get a calibrated MAF (and replace your perfectly good 70mm one.) Then gte your TB with it. In the end you would have spent hundreds of dollars and MAYBE gained 3 - 5 HP.
Before you just start throwing money at the car with mismatched and pointless parts, sit down and come up with a plan. If you are serious about modding the engine, you'll quickly learn that 24# injectors wont do **** for you.
RE: Summit Question
ORIGINAL: r0k0
i just want small mods.. not big ones... lol.. i wanna kept it kinda stock looking without the big mods..
RE: Summit Question
seriously, dont muck with anything on your engine until you have gears installed
then do a full exhaust, k&n filter, and call it a day.
TB, MAF, and 24# injectors would be a complete waste on your car
RE: Summit Question
ok what kind of gears... im looking for quick accelaration but lots of speed on the gears.. like my gears are great.. great accel and getting 60km 1st gear at 5500rpm and 105km in 2nd gear at 5500rpm..
