What is this?
Okay, new to Mustang question, save me the following the lines to figure it out. Look at the 2 pictures and tell me what the items are and what they do. They are both found in the passenger side of the engine bay on an 88GT.
Also, 3 rd picture is steering after installing tubular K member, I will need a spacer or longer shaft, ideas?
[IMG]local://upfiles/10436/E156861DB0A041C2B2BBA09581ABCAAD.jpg[/IMG]
[IMG]local://upfiles/10436/1E61E150BA23448FABCC5EDABCE5F8B1.jpg[/IMG]
[IMG]local://upfiles/10436/7694C4C90B4B4E2EB4E85F5C0122318C.jpg[/IMG]
first pic is carcoal cansister...sec pic some kind of relay ..3rd pic i had same prob just nocth out a little on the k member make a half moon cut ..ill see if i got any pics of mine that shows it good
ORIGINAL: hotrodmanII
ORIGINAL: angcobra
Where does the vacuum line that goes through the firewall go to? What is the little solenoid for?
ORIGINAL: Obsol3te
If you tossed your smog pump you can ditch that "canister"
ORIGINAL: angcobra
what did you notch? I slid the k member all the way back and the steering linkage is not long enough to reach the new location of the rack.
did you try pulling the steering shaft out from the firewall..??
ORIGINAL: angcobra
