help!!!!!!!!!!!!!!!!!!!!!!
Old Aug 19, 2007 | 09:20 PM
5.0 lou's Avatar
5.0 lou
Default help!!!!!!!!!!!!!!!!!!!!!!
i just bought a power steering pump because the one on my car went bad well i install the new one and the pully is loose and if im not mistake it should be pressed in what do i do???? please help i have no ride to work tomorrow
Old Aug 19, 2007 | 09:21 PM
danltr450's Avatar
danltr450
Default RE: help!!!!!!!!!!!!!!!!!!!!!!
in the center of the shaft there is a threaded hole. install a long bolt and use a washer and but to force the pully on.
Old Aug 19, 2007 | 09:23 PM
5.0 lou's Avatar
5.0 lou
i tried the bolt that came with it and it wont thread in only the begining of it i have tried a million bolts and none works
Old Aug 19, 2007 | 09:25 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
If you had to remove the old one with a puller then all is well you should have to press on the new one with the bolt and washer set up that comes with a new pump....if your's slides on...I'd suspect a worn shaft pulley on the reman one and or the wrong pump....I'd take it back and exchange it for another one...
Old Aug 19, 2007 | 09:31 PM
5.0 lou's Avatar
5.0 lou
the oldpully just slid off it had gotten loose in the past and i had it held with a bolt does this matter
Old Aug 20, 2007 | 09:15 PM
5.0 lou's Avatar
5.0 lou
ttt
Old Aug 20, 2007 | 09:27 PM
mattdel's Avatar
mattdel
if you can slide the pulley off the old pump, AND slide it onto the new pump, have you considered the pulley might be worn? too tight of a belt can cause a press-on pulley to come loose from the shaft.
Old Aug 20, 2007 | 09:30 PM
5.0 lou's Avatar
5.0 lou
yea im going to be tryin out a new pulley tomorrow im getting it from a friend cuz ford wanted 67 bucks for that crap
Old Aug 20, 2007 | 09:31 PM
mattdel's Avatar
mattdel
i bet your old pump isn't even bad. i bet the pulley is spinning right around it.
Old Aug 20, 2007 | 09:35 PM
5.0 lou's Avatar
5.0 lou
yep thats what i was thinking to but ehhh should the new pump eliminate the whine my old one had or is thats fords trademark? lol
