Compression 65psi?
Old Aug 21, 2007 | 11:45 PM
Kick_Ass2k1's Avatar
Kick_Ass2k1
Default Compression 65psi?
My friend's 5.0 started knocking and I did a compression test on it. The haynes manual says that compression should be minimum 101psi. I tested #1 cyl and got 55psi. On #2 I got 60 psi, and on #3 I got 65psi. Then I was like woah, this is half of what it should be. To check to make sure the guage was reading right, I went over to my LX5.0 which runs perfectly fine and tested #2 and got 75psi. Do I have a faulty guage? Or is my friends engine really bad and just found out mine is going bad too? Will the engine seem to run fine with such low compression? I'm a little worried
Old Aug 21, 2007 | 11:49 PM
ahittz24's Avatar
ahittz24
Default RE: Compression 65psi?
make sure you have all spark plugs out and turn the engine over a min of 3 times. Thats how you get an accurate reading.
Old Aug 21, 2007 | 11:52 PM
Kick_Ass2k1
I actually started the engine and let it run for 3-4 seconds
Old Aug 22, 2007 | 12:01 AM
blahman20's Avatar
blahman20
Good idea! I think i'm going to take a compression test tomorrow....so you suggest to take out all the plugs and crank it over 2-3 times each cyl?
Old Aug 22, 2007 | 12:43 AM
ahittz24's Avatar
ahittz24
Correct, Remove all plugs, remove coil wire, turn engine overa MIN of 3 times per cyl, not 2-3
Old Aug 22, 2007 | 06:30 AM
WhiteWindsor's Avatar
WhiteWindsor
Get engine warm, remove spark plugs, remove coil wire, turn engine five revolutions, and prop pedal to WOT.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
