PLEASE HELP
Old 08-24-2007, 11:12 AM
URLOSEN
URLOSEN's Avatar
Default PLEASE HELP
guys i need some help, i just put my new exhaust on my 94 GT 5.0L and now i can't get it started, i think i might have hit a wire or something but the car will not roll over at all, all my accerories are on but when i turn the key all i hear is a relay, (i think) but if anyone has any advise about it, thanks,
i think it is my neutral safety switch maybe, or a bad ignition switch,
the car was running perfect befor the install
URLOSEN is offline
Old 08-24-2007, 11:14 AM
v8 all the way!
v8 all the way!'s Avatar
Default RE: PLEASE HELP
What part of the exaust did you put on?
v8 all the way! is offline
Old 08-24-2007, 11:18 AM
URLOSEN
URLOSEN's Avatar
i put a new h-pipe on, and flowmasters super 40 mufflers
URLOSEN is offline
Old 08-24-2007, 11:22 AM
v8 all the way!
Okay did you diconect the battery when up unplugged the o2 sensors?
Old 08-24-2007, 11:24 AM
URLOSEN
URLOSEN's Avatar
ah **** i can't remember now, but i think i did, is that a big deal or what?
URLOSEN is offline
Old 08-24-2007, 11:26 AM
v8 all the way!
Um iam pretty sure if you unplug them without disconnecting the battery they get shrown off and that could maybe be the problem your facing. Its the only thing i could see that could mess with your exaust.
Old 08-24-2007, 11:29 AM
URLOSEN
URLOSEN's Avatar
thanks but do you knwo anything i can do to fix it, or of anything else that i could have hit putting it in, or somehting like that, like a safety switch on the trans, or somehthing like that?
URLOSEN is offline
Old 08-24-2007, 11:30 AM
TwotoneVert
TwotoneVert's Avatar
Not sure. But to remedy the problem v8 is describing. Un-hook the battery for at least 5 minutes and this will reset the ecu memory. Are you sure you didnt pull a wire from the starter or have something in contact with the starter wires? Were you anywhere near the tank?
TwotoneVert is offline
Old 08-24-2007, 11:32 AM
v8 all the way!
I dont know bout the tranny or anything else you cuolda hit. I have a 94 and everything is pretty clear on the underneath side of the car. Iam sorry man. Wish i could help more but def try to get some others with more knowledge then me k. sorry man. Good luck!
WhiteWindsor
WhiteWindsor's Avatar
I dont see how you could have bothered this, but check your engine ground, the cable that runs from neg. side of batt. to engine. Make sure your terminals are tight on batt. also. It has to be something simple.
WhiteWindsor is offline
