smog port plugs
smog port plugs
will running my 5.0 (smog pump removed, no cats) without plugs in the ports on the heads (E7) be really bad?
I do not have it running yet (at school) and I dont know where to find plugs for them, or if I should just use some short bolts to cover them up...
thanks
thanks
RE: smog port plugs
dont weld the bolt. i dont remember the size but you can thread a bolt in there. if you dont cover/plug up these holes, then it will smell really bad and there will be carbon buildup around the holes.
RE: smog port plugs
5/8"-11. They need to be about 3/4"-1" long. It you cant find those them make some cover plates and use some 5/16"-18 bolts and bolt them on using the holes that hold the smog tube on. Thats what I did.
RE: smog port plugs
ORIGINAL: Boss_Hotrod
