Typhoon vs. Trickflow
RE: Typhoon vs. Trickflow
90lx..you make no since..why do I say that you buy a typhoon intake to save $$$$ right so why the edlebrock t/b..why not save 60.00 and get a nice polishing one that the tps can be adjusted for professional products???????
for375- 450.00 I would buy a used gt-40!!!
Ok, I saw the Cobra intakes on ebay for about $380 and it came with all the hardware and gaskets.. The Cobra intake flows just as well as the Typhoon or Trick Flow?? I can spend more, I just want to get a good flowing intake to increase power from idle-5500 RPM.. 1.7's are going on at the same time, keep that in mind.. So should I get the cobra intake?
Edit: What is the difference between the Cobra and the GT-40 intakes? On ebay they say GT-40/Cobra Intake 5.0L .. Are they the same thing?
Vfast..Blah!...the cobra intake does not flow as good as the trickflows and typhoon. Its obvious just from looking at it bro!. Its a improvment from the stock 5.0 one, but not as good as the TF's and typhoon.
That is what I was thinking.. I have seen a lot of people with them at the track, but I see a lot more with the TF's and other after market intakes.. I hear that the cobra is not that much better than the HO intake.. I am thinking about going with the TF just because it seems to be the most common upon big power cars, are they Street legal?
Does the Street Heat and Typhoon have the EGR ports on them and stuff? This car must stay emissions legal.
ORIGINAL: vfast
The intake has NO moving parts and mine didn't need gasket matching, the T/B is another story, so before you say I make no sense, ask first.
I didn't want to spend money on another T/B but I had no choice.
ORIGINAL: 91hatchgt
Sweet, they both sound pretty good, I think I will go with the street heat Intake. Looks good too, hmm.. Thanks a lot for all of your help.. I appreciate it very much. Do you have an intake spacer? I was thinking about getting one of those, supposed to help out a little.. [sm=thanx.gif]
ORIGINAL: 91hatchgt
