I need Everyones immediate help!
I recieved my smog pump eliminator kit today and i have no clue to as what must be done to install it. The kit came with no directions. What must me done with all of the hoses and wires going to the smogpump.
I have a show to go to tomorrow and i was hoping to put this on tonight. Could you guys help me with my dilema! By the way it is going on a 89 gt.
Thanks Matt
Thanks Matt
RE: I need Everyones immediate help!
plug all the holes that go to it. the back of the head has a spot that needs to be plugged, the midpipe has a tube that needs to be plugged. pull the smog pump out, put the pully/wheel in its spot and put the belt on.
haha, you have to make it. There is a port off the back of each head. Why don't you just remove everything? That would make it look ALOT cleaner since you are going to a show. Instead of putting a pulley that does nothing...
ORIGINAL: MikeVa
Behind the heads, get (2) 5/8"-11, 3/4 inch bolts. You may have to clean the threads first.
ORIGINAL: 945LSTANG
you didnt have to waste your money on a pulley kit. you couldve just bought a shorter belt.
