speed density cam
RE: speed density cam
ORIGINAL: mattdel
hmm... thats a pretty neat trick if it really works?
i would think it would just muffle the "pulses" instead of lowering the count
ORIGINAL: AdderMk2
Zack, dont forget about the fuel filter you installed in the vac line to the MAP sensor... which helps cut down on the "pulses" that the cam sends to the map..
its an old MS trick
ORIGINAL: AdderMk2
As for the idle plate you can get it here:
http://www.latemodelrestoration.com/...1&comp=LRS
I got mine used for $10 though.
ORIGINAL: ZachW04Stang
Yep that helped out too but I've noticed that throttle response is alot better when its removed.
ORIGINAL: AdderMk2
yo dime i know this may be late but hope this helps at all
http://www.50tech.com/viewtopic.php?t=50694
its like half way down.
Hey, if it were me, I'd make sure that I got the springs that the grinder recommends for the cam, new set of pushrods etc.
Also, while the heads are off the car I'd want to do a real good 3 angle valve job........
