carb setup
ok yea i kinda think i want to get a vic junior or this other one i found on ebay with a 670 street avenger. this is the intake i found: SBF FORD 302 PARKER INTAKE MANIFOLD 306,331,347 MUSTANG
that intake with the 670 or 650cfm and an f303 cam for now.
http://www.tristatecylinderhead.com/...roducts_id=120 anyone know if these heads will work well with the parts im looking at in the above post?
That intake is way overkill unless you plan on a big cam and revving it to 7k+. Same with the heads. That stuff would work better on 331 or 347. If you plan on bolting them to a stock bottom end it'll be a dog.
More details on the car would help.
its an 88. as far as i know its a stock bottome end out of a 95. right now its got typhoon intake and throttle body. it has a maf conversion but im not using it, for some reason its running on the speed density comp. its got 3:73s i plan on changing the trans and clutch out cuz i dont think its gonna last much longer.i want to change it to carb later on. once i do thats when ill do h.c.i. and hopefully leave the bottom end stock for a little while but later on ill have some plans for a bottom end ill be throwing this bottom end out.
bradleyb
Nov 27, 2015 07:50 PM
