TPS?
Old 02-11-2005, 03:33 PM
90Mustangfan
I ♥ Acer
90Mustangfan's Avatar
Default TPS?
what exactly does a tps do? would it make the car run bad if its set to more than .99?why does it have to be set at .98 or .99?NEED INFO
90Mustangfan is offline
Old 02-11-2005, 04:33 PM
Quik
Quik's Avatar
Default RE: TPS?
to high or to low is bad. ot hight youll get backfires after you let off. it sends a signal to hte ecu to help with air/fuel
Quik is offline
Old 02-12-2005, 12:19 AM
619socalstang
619socalstang's Avatar
Default RE: TPS?
the tps tells the ecu where the throttle is, then the ecu sends the corisponding message to the injectors to add fuel to match the throttle position.
619socalstang is offline
ShaneB26154
35
03-04-2021 04:05 AM
mirandaandjimmy
11-16-2015 08:51 AM
JonnyBlazeGT
11-03-2015 01:10 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
bmorrisj
05-27-2004 06:18 PM
Quick Reply: TPS?
