Couple issues
Couple issues
My car is running ok, but it seems like its lacking in power... i have a suspition that im running on 7 cylinders, but theres no smoke, and no back firing, but i want to check anyway, besides spark plug wires and plugs, what else should i check
also, when i let off the gas, it stays the same RPM for about a second, and then goes down, what could cause this, its been doing it for a while, and its not the TPS
the reason i think im missing a cyl is because it idles a little rough, and i have almost no power past 2nd gear
RE: Couple issues
Crank it up and start pulling wires. If you get to a wire that when pulled it does not affect the engine, then you have found the dead cyl. Now all that other stuff is efi and i cant help you too much with that. But i would take off the iac and clean it real well, it could be sticking. Inspect your dist. cover well for cracks and see what your rotor looks like. It could just be time for a tune-up. Wires, plugs,dist. cap,rotor,air filter,fuel filter.
RE: Couple issues
Not to hack your thread...[/align][/align]i have the same problem on my car with the RPMs staying when letting off the gas to shift. i have replaced my fuel filter, air filter is newer, cap, rotor, dist. coil, checked timings and cleaned IAC and it still does it. along the way i discovered i was running very lean and i ordered new injectors that will be here tom bec mine were not misting, they were streaming. but i still dont know why my RPMs hang like op described... [/align]
RE: Couple issues
Whoa now, adding bigger injectors is probabaly not going to solve anything. Make sure the T.B is cleaned out and check for vaccum leaks. Sound like you need a new fuelfilter, as mentioned. Make sure the MAF senor is clean while your at it. The igniton conmonet need to be in workin order. Fix the problem before you try to modify, you just end up compounding the problem. Run some injector cleaner through your next tank of gas, too.
RE: Couple issues
ORIGINAL: bikeboy587
Sadly, the cable is about $80 new if you get a deal and not available aftermarket for the Fox.
RE: Couple issues
yeah, i replaced the filter, and it SEEMS like it fixed it, wont really know until tomorrow, but im still gonna get some seafoam and run it through the tank.
P.S. YAY for rusty coolant, you can guess the rest
