Fuel Line **PICS INCLUDED** help!!
ok im trying to figure out if its my supply line or return line thats cracked. how can i tell? im right where all the mess is and i cleaned everything up and i have no idea which one it is and i cant pull them apart because of the clamps they are in and it doesnt look like they come apart unless i can pry them apart. should i cut both lines? let me know if you need pictures
RE: fuel line....quick help plz
A pic would be really helpful if you can get one.
I think the clamp your referring toisthe spring-lock coupling and that will require you to use a tool you can get at almost all auto parts places.
I wouldn't cut a thing until more chime in if it were me.
its actually closer to the fuel filter. about 2 feet of line past the fuel filter above the rear end. ill posta pic here in a second. the clamp is whats hold the lines to the body of the car i know that much. youll see in a second.
let me know if you need more pictures or whatever. i hope you can help me identify whats bad. in picture #2 and #3 you can see the break line the runs near the rear end snubber. thats COVERED in whatever but it smells like raw gas. im almost positive its gas that i smell when i get on it real hard. so i doubt its break lines. you tell me though.
