pulling the 5.0
Old Sep 18, 2007 | 06:18 PM
r429460's Avatar
r429460
Default pulling the 5.0
Is there something I am forgetting? Theeng. starts to seperate from the trans. but it wont pull out. Headders off, intake off, motor mts. unbolted from the block, all ***. fromthe front removed. Clutch cable off, starter off. 6 bellhousing bolts off. 2 lower cover bolts off. Whats missing?
Old Sep 18, 2007 | 06:39 PM
creekrat's Avatar
creekrat
Default RE: pulling the 5.0
There are 2 locating dowels that align the bell to the block. Sometimes they stick.
Old Sep 18, 2007 | 06:56 PM
r429460's Avatar
r429460
Hmmm, the block pulls away from the trans. at the dowels, but will not seperate all the way. Is the fly wheel so close to the bellhousing causing this?
Old Sep 18, 2007 | 07:27 PM
five0fm's Avatar
five0fm
wait are u pulling the bellhousing with the engine or is it attached to the transmission
Old Sep 18, 2007 | 08:00 PM
creekrat's Avatar
creekrat
Also may be the TOB hanging up on the input shaft housing
Old Sep 18, 2007 | 08:24 PM
92civy's Avatar
92civy
what about the clutch fork????
Old Sep 18, 2007 | 08:40 PM
monkeyboy's Avatar
monkeyboy
Could be worn input shaft splines if it has alot of mile and hard use.
Old Sep 18, 2007 | 09:14 PM
r429460's Avatar
r429460
I searched and found that some say its easier to pull the eng and trans together. I think ill do that.Unless it comes out thursday with one more pull.
chrisdbassplayer
Oct 13, 2015 06:53 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
jrrhd73must
Oct 2, 2015 09:17 PM
treesloth
Sep 28, 2015 07:03 AM
