trans shift question
Old Sep 19, 2007 | 01:36 PM
rembull's Avatar
rembull
Default trans shift question
I recently had 410 gearsput in.93 must with ford gt40 crate motor. Is there a way to fix the early shift points now. It is in overdrive at about 30 miles per hour?
Old Sep 19, 2007 | 02:54 PM
MEM 302 5.0L's Avatar
MEM 302 5.0L
Default RE: trans shift question
I put in a shift kit, and stall converter in my AOD mustang...and i fiddled with the throttle cable, and it still shifts between 30-35mph into overdrive (with 4.10 gears), just leave it in drive if u dont want it to shift yet.... you'll probably get better gas milage if you let it go into overdrive though, i do, but i dont think its good on the car to be going that slow in your final gear...
Old Sep 19, 2007 | 06:38 PM
SpitnCobra's Avatar
SpitnCobra
Nope. If you wanna change your shift under normal driving, shift it yourself with a B&M Hammer shifter you will love it, i do. But a warning outta come with that shifter it's addictive...lol
Old Sep 19, 2007 | 06:53 PM
98MustangGT46's Avatar
98MustangGT46
I leave mine in drive. I only use overdrive on the highway. And i dont have 4.10s yet.. I cant wait to get them..
Also just curious with the 4.10s what rpm are you at in 3rd gear/drive cruising at 35-40 mph.
Old Sep 19, 2007 | 07:16 PM
MEM 302 5.0L
um 35 is about 1600 rpms i think and 40 is close to 2k in over drive ...35 is about 1000 rpms i think
creekrat's Avatar
creekrat
Get a Bauman shift kit. You will be able to adjust your shift points higher in the RPM range and also how hard the shifts are.
97SN95GT
Sep 13, 2015 09:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Mustangmalo
Sep 6, 2015 05:22 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
