next upgrade?
next upgrade?
lets see so far i have performance wise~~~~ e-cam, 3.73s, cold air, 75mm maf i think, k&n filter, short shifter, bbk shorties, offroad h, flowmasters, what would the next bang for my buck be?
RE: next upgrade?
Here's MY mods list... this should give you a few ideas.
Flowtech Longtube Headers
Flowtech O/R H pipe
SLP Loudmouth Catback
Eibach Sportline Springs
Tokico Gas Shocks/Struts
Addco Swaybars
Steeda Camber Caster plates
Kirban Adjustable FPR
Granatelli Motorsports rear upper and lower control arms
CHE Performance Axle Brace
Fender mount CAI
Professional Products 70mm throttle body
ARP Head Studs
ARP Water Pump Bolts
ARP Intake Manifold Bolts
ARP Oil Pan Studs
ARP Oilpump Driveshaft
High Volume Oil Pump
www.fordstrokers.com Liberator 347 Stroker
RHS 180cc/58cc Iron Heads
Scorpion 1.72 Roller Rockers
Camshaft Innovations Custom Cam
Trickflow Track Heat Intake
36# Fuel Injectors
Ford Racing underdrive pullies
Hurst Pro Billet short throw shifter
Triple Hook Billet Quadrant
Billet Firewall Adjuster
Steeda Adjustable Clutch Cable
Ford Racing Aluminum Driveshaft
Ford Explorer 31 spline T-lok differential
Moser 31 spline axles
3.73 FMS Ping and Pinion set
AEM 6in1 Wideband Controller
Walbro 255LPH HiOP Fuel Pump
Spec Stage 2 Clutch
Lightweight Aluminum Flywheel
Megasquirt 2 v3.0
2 Stage Nitrous System - 75 dry, 150 wet
Flowtech O/R H pipe
Addco Swaybars
Fender mount CAI
ARP Head Studs
ARP Oil Pan Studs
36# Fuel Injectors
Spec Stage 2 Clutch
Megasquirt 2 v3.0
