heater core, etc...
Old Feb 16, 2005 | 07:40 PM
90Mustangfan's Avatar
90Mustangfan
I ♥ Acer
Default heater core, etc...
Ok you know where the two heater hoses go into the firewall. well about 4-5inches below those hose there is a hole. My dad said its from the heater core and has to do with letting out condensation from the a/c or something, well every morning there is a small puddle of coolant on the floor that dripped from that hole on to my exhaust pipe, and then on to the ground.Does this mean my heater core has a leak? how hard is it to replace my heater core? why is coolant slowly leaking out of that hole?
Old Feb 16, 2005 | 07:45 PM
mustang8719's Avatar
mustang8719
Default RE: heater core, etc...
Sorry for your pain[sm=patriot.gif]yes it is your heater core.It is kind of a pain in the A** to replace.Do a search for heater core replacement and some where there was a link to show how to replace the heater core.
Old Feb 16, 2005 | 08:03 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Bacon just changed his, Im sure he'll help you out with some hands-on info. Until you fix it you may want to remove the hoses from the heater core and run them into each other with a coupling, you wont have any heat but it wont be dripping either.
Old Feb 16, 2005 | 11:32 PM
Tims 88GT's Avatar
Tims 88GT
I did mine before i wrecked my car all i have to say the easy way to do it is take the whole dash off you can do it with it loose but i think it is more of a pain that way. if you take the dash out the center console has to come out first.
P.s. take off your shifter handle to
Old Feb 17, 2005 | 10:02 PM
speedshifter's Avatar
speedshifter
Default not that hard
Did a heater core in my buddy's '91 LX 5.0 w/AC a few months ago. It wasnt that hard. We had it done in under 4 hours. Book labor time is like 8.2hrs. I yeah the dash has to come out, but after that its a breeze. You really dont have to take the dash out, you can just unbolt it and prop it up on the right side and work around it, but it really only takes like an extra 10 mins to take it out and put it back in once you are there. 2 people make the job a breeze. Don't disconnect the airbag and take off the steering wheel like the Ford service manual says, just disconnect the battery in case you do anything stupid and work around your non-tilting steering wheel.
I'm a GM tech and i find it hilarious how i can take apart an entire GM dashboard with a 5.5, 7, 10, and maybe even a 13mm socket, but the fords i work on use all the sockets in between that ive never even touched. That one thing i've noticed with ford is they use some odd ball fastner sizes and there is very little consitency in size.
Oh well, have fun!
Old Feb 17, 2005 | 11:04 PM
Tims 88GT's Avatar
Tims 88GT
Default RE: not that hard
it took me like 7.5hr and i dont want to do i again but if you have any questions just ask.
Old Feb 17, 2005 | 11:05 PM
Tims 88GT's Avatar
Tims 88GT
it took me like 7.5hr and i dont want to do i again but if you have any questions just ask. i will have my dash off again this week cose i need the wiring out of it to put in the new one.
Old Feb 18, 2005 | 01:11 AM
Hannys5.0's Avatar
Hannys5.0
Changing mine tomorrow...book does call for 8 hrs so i will see how that goes and let you know.
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
2016PP
Sep 23, 2015 09:51 AM
Calizic
Aug 28, 2015 01:46 PM
Mnuckolls
Aug 9, 2015 08:54 AM
