KOEO code......
Old Sep 21, 2007 | 01:50 PM
tiburon's Avatar
tiburon
Default KOEO code......
What the crap is code 67 (neutral drive circuit) what does this code mean and do I need to worry about it?
Old Sep 21, 2007 | 03:33 PM
Texas5.0's Avatar
Texas5.0
Default RE: KOEO code......
Did some google searches and found
Code 67 - Improper signals are being received from either the Neutral Drive Switch (NDS),Neutral Gear Switch (NGS),Neutral Pressure Switch (NPS),Clutch Switch (CS),Manual Lever Position Sensor or Air Conditioner Clutch.
Was the A/C on when you did the test? Or if a manual was it in gear?
Old Sep 21, 2007 | 08:07 PM
tiburon's Avatar
tiburon
Thanks for lokking that up. I re-tested and this time I made sure it was in neutral and moved the stick back and forth a few times. Code 11,11 11,11 only! thanks again
1TUFF302
Nov 5, 2015 04:02 PM
SteelerNation82
Sep 16, 2015 07:11 AM
95w.i.p
Sep 3, 2007 07:59 PM
buckshot
4 Cylinder NA and Turbo
Jun 19, 2007 08:59 PM
90Mustangfan
May 27, 2006 07:57 PM
