Royal Purple
Old Sep 21, 2007 | 03:54 PM
CHILLERMAN's Avatar
CHILLERMAN
Default Royal Purple
So I did a clutch job this past week-end. Decided to change the fluid in the T-5. Went with royal purple synchromax. Transmission shifts alot smoother than before. What has been everyones experience with royal purple gear lube in the differential? Is there any appreciable HP gains at the wheels to make it worth the difference? All the guts in the differential are new.
Old Sep 21, 2007 | 04:18 PM
holyshift's Avatar
holyshift
Default RE: Royal Purple
Ive never used Royal Purple in my diff, or tranny, but recently put it in my motor, and so far it seems to be just like any other oil i suppose, but it really hasnt had time to break in, just a few passes at the track, well see.
Old Sep 21, 2007 | 08:46 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
I run it in both our stangs, trannys and rears. So far so good.
Old Sep 22, 2007 | 10:13 AM
CHILLERMAN's Avatar
CHILLERMAN
Thanks PRO50, Just wanted to hear from someone who has had experience like you. I do industrial/commercial air conditioning and we use royal purple exclusively in all our gear drives in cooling towers. No problems yet! I just don't haveenough people here locally to ask about their automotive applications.
Old Sep 22, 2007 | 10:15 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
NP! But gears are gears, if you're using it successfully for industrial applications, it would be fine for automotive use.
Old Sep 22, 2007 | 01:01 PM
88BlueGT's Avatar
88BlueGT
I recenently just switch motor oil from RP to Mobile 1 just to try it out but Im running RP in the rear. NP's.
Urambo Tauro
Oil and Oil Related Topics
Dec 11, 2017 07:16 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
newcrazycar
May 15, 2004 12:50 AM
04mustang
May 9, 2004 10:55 PM
