Spec Stage 3
anyone use this clutch before? if so how did the pedal feel and how well did it grab? i also herd somthings like spec clutches dont like to fit to well something with it not clearing the bellhousing and if this is in the wrong section im sry
I use the Spec stage 3. The pedal is light and it grabs awesome. Never heard of a problem with fitment. I dont know what you have but i would not use this clutch unless you have the power recommended for the clutch.
If you have a stock mustang or mildly modified one then it's overkill as fastblack said if you don't have the power for it don't get it
...I know people aren't a fan of this here and say it's junk but I'm using A King Cobra clutch and run low 11's on it with the juice with no problem
I just put a Centerforce dual friction in my wifes 90 vert. Her car is mostly stock. She ran it at the track over the weekend on a pair of et drags and it worked out well. It grabbed nice and has a light pedal feel.
ORIGINAL: mjr46
ORIGINAL: 8banger
Spec 3 here...grabs great....heavy, stiff pedal(compared to my King Cobra setup).....when its new ,will chatter abit...untilit wears in ....
spec clutches dont slip. but now I have broken 3rd gear in my t-5, and my rear gears because of it.
if you have less than 500rwhp the spec 3 is too much.
I just took a Spec Stage 3out of my car with the Billet steel flywheel, killer clutch though, one of the hardest hitting ones ive used,....selling it all too, lemme know if your interested
