Roller or not??
Old Sep 25, 2007 | 07:56 PM
hillbilly pony's Avatar
hillbilly pony
Default Roller or not??
This should draw some opinions.
Should i keep my 1980 block a flat tappet or get the crazy roller conversion thing and convert. does it really matter??
Old Sep 25, 2007 | 08:02 PM
white93pony's Avatar
white93pony
Default RE: Roller or not??
well it depends on the purpose of the engine is it a daily driver with the occasional track use are you planning on running high rpms i would recommend hyd roller setup but if your planning on pulling high rpms then maybe using solid roller i personally like the roller setup better less friction quicker revvs its easier on valve train parts smoother running just my 2 cents
Old Sep 25, 2007 | 08:08 PM
Jfsram's Avatar
Jfsram
Many advantages and disadvantages to either.
As long as you can afford it, roller is the way to go.
Old Sep 25, 2007 | 11:21 PM
92GreyGT's Avatar
92GreyGT
Solid roller. Many manufacturers have street rollers and with todays technology you may have to adjust valves 4-5 times a year. That is if your wallet can stand it.
Old Sep 26, 2007 | 12:09 AM
67mustang302's Avatar
67mustang302
Hydraulic roller for the street, more power and reliability than flat tappet, set it once and be done
Old Sep 26, 2007 | 09:44 AM
Gary H's Avatar
Gary H
Skip the conversion and just get a later block if you want the roller. Alot cheaper. You can make good HP with a flat tappet cam too though.
uedlose
Sep 30, 2015 08:01 AM
Tyoung68
Aug 25, 2015 04:31 AM
WDScott
Aug 17, 2015 06:38 AM
johnc
Dec 28, 2003 12:29 PM
92notch50Liter
Feb 18, 2003 11:52 PM
