brakes slowly went bad and now they quit
RE: brakes slowly went bad and now they quit
well if u say ur pedal started to go softer then most likely its ur brake master cylinder.if its a booster problem then ur pedal would get stiffer not softer.either its the master or there must be a tiny leak somewhere...cuz as soon as theres a leak,air get in the system and u would have to bleed it.but thats the temporary fix,gotta find the leak first.
The leak could be from the master cylinder where it meets the booster and it may be leaking into the booster.Look under the master cylinder where it meets the booster and see if it is wet or if the paint is gone.If so you might want to do the booster at the same time.I have been the twice with my car.The master leaked and took out the booster as well.
the vacuum line went on mine, i maintained my brakes, but my pedal got REAL hard just like it feels when you pump the pedal when teh car is off. but i still had brakes but no feel in them
