damn gears
Old Sep 26, 2007 | 02:45 PM
dimebag's Avatar
dimebag
Default RE: damn gears
uh yea... gear oil in a t5 is a no no... go get some atf now, lol... and its just a hair under 3 qts... fill to the bottom of the fill hole...
Old Sep 26, 2007 | 08:56 PM
stang8689's Avatar
stang8689
Use royal puple or gm
Old Sep 26, 2007 | 09:11 PM
69MustangCoupe393cid's Avatar
yeah umm gear oil is bad lol. Ill agree with royal purple or gm's syncromesh.
Old Sep 27, 2007 | 05:28 PM
Jfsram's Avatar
Jfsram
If your pedal is still hard to push down and you've already replaced everything. It could very well be the cable.
I had my cable out of the car to lube it up and noticed ONE strand that was broken. I figured I'd replace this before more broke and eventually snap. The difference is amazing. It's almost like going to a lighter clutch. If I had to put a number on it. It's like going from a 2300lbs clutch to a 2000lbs. Bought mine a Steeda.ca for $40.
As for the 80w90 gear oil. When I bought my Mustang it had gear oil in it.
Like many member believe, including myself. It was time to change to the correct fluid.
Besides taking "a slight bit" of notchiness out in the true dead cold mornings.
It shifted and worked exactly the same as it does now. The difference is minor.
Old Sep 30, 2007 | 03:32 PM
topless91gt's Avatar
topless91gt
I would get the gear oil out of there ASAP!
I just changed my tranny andclutch and had the same problem with the stiff pedal and rough shifting. Get an aftermarket quadrant, a firewall adjuster, and a stock replacement cable (NON-ADJUSTABLE) from Steeda! Stay away from the adjustable cables!! Just put on my steeda cable last week. GREAT quality!!! Fit perfect. Slap it on there and turn your firewall adjuster to fine tune where your clutch releases!!! My pedal is almost as soft as a hydraulic clutch and thats with a king cobra clutch..
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
