anyone using a aod for with a stahl conv.?
RE: anyone using a aod for with a stahl conv.?
Hey thanks for all the reply's! I'm runing 410 gears with 25.8" tall tires with the AOD 3000 stall. I'm concerned that the motor might hit red-line 6000 rpm before the trap on the Quater Mile.
Is anyone letting there aod go into overdrive before the trap?!?
with your combo! hell naugh; that thing is gonna lauch like a rocket and keep pulling past trap.
347 STROKER 10.2.1 COMP. 410 GEARS 3000 STALL 185 AFR HEADS SHORTY HEADERS MAC EXHAUST NO CATS SUB FRAME CONNECTORS 150 SHOT NITROUS 544 LIFT COMP. NITROUS CAM 1.6 ROLLER ROCKERS
If mine were not stick shift...I wouldn't put anything else in mine but an AOD cause I would want the overdrive feature for the street!!!! heck I even converted my 66 to a t-5 cause I wanted overdrive/needed it due to gears... a non overdrive equiped car limits you on cruising rpm's on the street
Yes,it has a B&M shift kit STG 2, ford Racing aluminum drive shaft, 255 lb.Walbro fuel pump, Pro M.80mm. mass Air cali.Custom burned Chip.AndI drive it every Day...
